Talc is pretty good at attracting moisture; maybe that's the basis for the OP's question ?
If you want no talc, you're looking at something like the reinforced filler, aka "kitty hair".
Sands like concrete in comparison, but doesn't suffer moisture contamination.
In a proper environment & with proper procedures, moisture contamination isn't really a problem.
