are there any prescott/chino valley arizona members or the surrounding areas that could help out a friend of mine that bought a 65 bel 1 off of moparts a few months back, or possibly you know of a shop there that can work on it? car was running great and then developed an off idle miss and #7 cylinder does not fire or has a weak spark. he took it to a so called shop that works on the older stuff, but they messed around and had him spend a bunch of money on carbs and did not fix the miss. im having him do a few things that he can handle, he is an older guy with not a lot of mechanical experience. we need somebody to take the valve cover off and have a look see and maybe do a compression/leak down, maybe check out the distributor. he wants me to pick it up and bring it back to so cal but im in the middle of selling my spread here and moving to tennessee. thanks and any input would help.
