Looking online what I found.
Error code U0100 means the PCM cannot send or receive communication signals via the CAN bus. DTC U0100 code usually comes up due to the following: Faulty ECM. Problem with control module wiring.
That could be your problem.
The other one is
BTW, if it ends up that it's an engine wire harness problem I have the one that I just took off my wife 2006 Charger Daytona that I just finished up installing a 6.4 stroker and I used an SRT wiring harness from a 6.1 on it so I have the original one available.
