Quote: If you want that thing done and are wondering about the stem seals,(looks like the heads have been off at some point), you can poke the seals with a pocket screwdriver through spring while the v/cvers are off to find if they're soft still or rock hard. It will give you a quicky piece of mind. Or are ya done already?
POKE WHAT? OK, what seals are they, what do they look like. I will check them out.
No, not done, got too frustrated and went back to what I know and started some body work ont he tail gate, radiator support and bed
and put doen some primer on a chest style coke machine that I a making a cigar humidor out of.
