Originally Posted by Dcuda69
Personally I'd have a good shop clean and mag the block then rough bore it to figure the final bore size. Most good shops won't final hone the bores until they have pistons in hand to calculate piston to wall clearance. Remember odd bore size pistons can be spendy...i,e. 010,020 etc. 030 is common and easily attainable.
