Originally Posted by DrCharles
Originally Posted by gregsdart
Originally Posted by Blusmbl
Originally Posted by metallicareload
Engine Masters did a thing on this and flex fans were generally the worst by a good bit. I think the worst one was a plastic fan at full flaps
x2. Best is obviously an electric fan. Next best is the clutch fan setup. The flex fans are worse for parasitic loss.
i had very good luck using a clutch seven blade fan on a 408. The clutch limits fan rpm, which limits power loss. Flex fans, not so much.
How about a flex fan mounted on a clutch? popcorn
The seven blade moves a ton of air at low speeds, making it efficient because max rpm it will see due to the clutch is tied to its huge capacity to move air.
