If you still run the ISO setup then you can use a 1 9/16" hole saw to open the spring perch to accept the locating pin and rubber isolator combination. Just bolt a plate to the underside of the spring perch so the arbor has something to bite into.
1987 Fifth Avenue - 512/518/D60
