What makes you think the parts were dipped at the casting plant? Do you have prints of the spec for this? Is your part an over the counter piece or from a car alternator? It still is possible, parts made for the dealer had a different spec, than assembled alternators being sent to the assembly plant. Newley cast parts going directly to assembly would not have needed a chemical treatment in my opinion. Something that might sit on a shelf maybe.
