I ended up using .103 Viton with a 75 durometer. We shall see. Hopefully a couple weeks it will be running if all looks well.
Barton said "any .10' rubber o ring" is what he uses. Viton takes the heat and 75 durometer is a little softer than 90 to take the shape of the area which is odd shaped.
CrAzYMoPaRGuY
