Originally Posted by A990
I found the setup document. It's pretty limited use, foam baffled fuel cells are a no go, and I suspect vertical installs are too.
Did you mean "Horizontal?" the instructions posted show a vertical install
I would also wonder about tanks like most of the Mopars that are mounted at the top front, but angled downwards?
The issue I see on top mounted senders is floor clearance>
Next would be making an adapter for OEM style tanks. That likely add to the height issue
shruggy
