Originally Posted by AndyF
Originally Posted by bonefish
can you share a little on the engine combo?
427 that has been stroked to 482 inches. Has Trick Flow heads and a tunnel wedge intake with dual throttle bodies. Fairly big street roller cam and pump gas compression made a little over 700 on the dyno. I think the cam might be too big for the street but we won't know until we try it.
Those exhaust manifolds are to flow pretty decent for that build.
