Originally Posted by JohnRR
A body only came with 1 arm without a console , bench or buckets .
Have you friend look for a 71 B body bench shifter and a 70 bench shift b only shifter box. The 70 B only shifter box has longer arms out the bottom to shorten the throw of the long 70 B shifter length, should work nice with the longer 71 lever. I'm putting one in my 69 dart to shorten the throw.
Thanks for this!
