Originally Posted by fast68plymouth
Are you not able to just flip the pulleys and go from 10% OD to 10% UD........ and see what that does?
Last yr I swapped the top pulley for -6% and got 12psi so not much reduction in psi and by charts it takes 5% for 1# if boost so I dropped it what I could with pulleys I have 55crank 67 blower and have a 50t for crank but felt that was way too small.
ps:the 6psi would give me an effective cr of 12/1 cr and should go with the cam ok.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
