there is no better sensation (maybe there are, in the bedroom ) than having enough power to break the rear tires loose at speed The trick is knowing when and how to drive it correctly, so you don't hurt the motor, car and yourself Be safe, have fun
Do you have your shift lights hooked up to the two hood turn signal lights?
