Originally Posted by hemienvy
Thanks Rumblefish, so the photos are the RB distributor on the 383 ?
As mentioned elsewhere you'll need the adaptor AND it's LONGER hold downbracket to use an RB distributor, that will push the body of the distributor up 3/4 of higher, the difference in length is below the block mounting surface.
running up my post count some more .
