The general rule with turbo vehicles is don't buy them used unless they're original owner with full service records. It's WAY too easy to abuse them and end up with big $$ problems.
These aren't like the 80's / 90s turbo junk. They have an aux pump that runs after shutting car off to cool down the turbo. I ran the absolute snot out of mine, low 15's at the strip with easy launches. You can get a canned tune for them that bumps power from 160hp to 230. They'll make even more but the trans will disintegrate over 250. I believe its now a 1.3L and they will be putting it in the Hornet R/T w/ elec motor and makes 383lbft of torque
