Originally Posted by dvw
If you want Torque Thust I would start with the biggest bolt pattern you can. 4 1/2 requires the lug nuts and spacers to be machined to reduce the diameter. Simply not enough clearance at 4 1/2" .
Though it can be doen as seen here. My American 200S were done the same way. 4 3/4 would help. 5" would be the best route. Headers were built by Ernie Miyomoto at Motofab. He does nice work. If this thing weighs anywhere close to mine it should be a runner. Best Machine dyno slip says 965. We'll see.
Doug
Thanks Doug, I would love to see your car in person one of these days! And I can't wait to see this '64 run, it should be a screamer.
I do know my current 1/2" tapered lug nuts are very tight with the 5 x 4.5 pattern, the impact socket touches the center of the wheel when I'm removing them. Found some aluminum lug nuts that are smaller and would likely work at 5/8" but I don't know if I trust those on the street.
'18 Ford Raptor, random motorcycles, 1968 Plymouth Fury III - 11.37 @ 118
