I don't have much room for an air-to-air or air-to-water intercooler in my '68 Barracuda, so I plan on spraying methanol (Alkycontrol) and and possibly adding a chiller (it's pretty small) to run off my A/C if it needs more cooling. I'm only running 14 lbs of boost though. I will also add the GM Flex Fuel sensor and mix E-85 with pump premium. https://killerchiller.com/shop/ols/categories/universal
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
