Originally Posted by 6PKRTSE
Mine Hemi is solid mounted in my 70 Challenger with front and mid plates in the stock location using Indy's passengers side relief valve covers and no clearance issues anywhere else with anything.
Whos plates did you use? Did you have to modify the floor tunnel for the midplate? And the starter and torque converter?
