Had same problem on a '98 1500. Had to tighten the puller to where I could feel it starting to strip. I then had a 1" piece of rebar I zip tied in place so it was resting on the top of the arm, and I could swing a sledge hammer from above. Did the trick, and I didn't hit the radiator, either.
