Hi! I would like to know if an AVS 2 1906 would fit my cast iron intake? I have a stock 1970 440 engine that has a stock 1971 intake. Also, will it work with a stock air cleaner and fresh air hood? Is it easy to hook up the electric choke? Can someone tell me the right part number for the carb for my car? It's a 4 speed with 354 gears. Finally,do you need an adapter for the intake for the carburetor? What gaskets need to be used?
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
