i was also under the impression you need to use the parking brake to keep the calipers adjusted when using ford calipers on the rear. and as was already mentioned, check to be sure you are getting the full travel needed with your brake pedal, and it's not hitting something under the dash causing it to stop before it reaches the travel necessary to fully use the master cylinder stroke.
