[size:11pt][/size] Well this will not be the first time, and absolutely not the last, that I over think something. About half of the cars we run around with, can go for hour and a half to two hour cruises to a show, but won't last 20 minutes in a parade.
That sir is not a radiator problem, but rather a lack of air flow through the radiator . A bigger radiator may help a bit, but the root cause is LACK of sufficient air flow,
