I'm more than likely keeping the stock front suspension and changing the upper arms to adjustable ones along with adding better later model disc brakes. This car was a slant six car so I'm open to swapping the torsion bars out also :help
give pete at
https://bergmanautocraft.com/ a call. he will get ya what you want. you'll want 1+" torsion bars, better leaf springs and a good size front sway bar along with good shocks with a proper alignment (not those crappy stock specs) at a minimum. tires will be a huge improvement too depending what you go with,,,
