thanks for the response guys,now what front shocks to buy,summit adj,are they junk,ce-or lakewood,lots of choices???
IMO, try the Calvert shocks if you are on a budget. Ive got a set and they separate very easily, way quicker and easier than CE's.
By the way I use the Calverts on the street and they are fine. I also used the CE's on the street since 90 or 91, no problems with them either.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
