Haven't posted on here in a while but here goes. I'm putting together a 440 Dakota. I bought a really clean 90 Dakota short bed and had this 440 laying around. Put a small cam in it and a set of 67 closed chambered heads to bump the compression.
Which headers are those? B-body? What size primaries?
What engine mounts did you use to fab ?
Do you have a factory truck oil pan or an aftermarket one?
Thanks in advance. I am in the middle of my 1988 440 build...It had motor plates, but I really want to use standard mounts.
