Ok, if Dr. Diff is not an option how about Mancini, or Randy's Ring and Pinion?
A shop that does 18 wheeler drivetrain service work should be able to do a gear swap as well if you give them the specs and parts. Cheaper to rebuild what you have vs a new one + shipping.
