If you have max wedge pistons like l have,use max wedge piston rods to. Max wedge pistons never had Ly rods on them.non heavier max wedge rods as stated above.has anyone used Ly rods on max wedge pistons? Seriously doubt anyone has.
LY rods have/had a 1000gram piston/rod on them from the factory, what is so SPECIAL about a max wedge piston other than it's compression height?
Many people talk up the 6 pack rod like it was the savior of the 440 , Chrysler fubared that one too , a heavy hemi sized rod with the small bolts from an LY rod ...
