Deepen the valve reliefs, create flame notches, shorten the skirts under the pins (non-thrust axis), but aluminum is 1/3 the weight of steel.
In some cases, the piston pin can be taper-bored from both ends, go slow, keep it wet & cool.
Boffin Emeritus
