all three of the OP's pictures appear to be of the same air cleaner
it has been modified - the carburetor bridges are gone & I believe the air shield has been added
this piece was sold thru Direct Connection/Mopar Performance in the late-'80s/early-'90s with the cutout on the driver's front for A/C compressor clearance
The pictures are so close, they are confusing. I see two air cleaners. One with the air shield and small notch on the pass side and another with no shield and the bigger notch on the dr side for the ac compressor. I’ve never seen one with the ac notch. It’s clear from the bottom picture that the bridges have been removed on the outboard carbs. I bet your right. They were modified for three Corvette carbs of three center Mopar carbs. I’ve used three center carbs at one time before. I did not modify an air cleaner though.
