Originally Posted by 360view
Originally Posted by fastmark
Well. I may try another attempt to modify this mount. I just put too much ͏H͏e͏at at one time. I knew better. This new mount is not even wide enough to fill up the space like the old old either.
Many users have bragged about making custom vibration isolators from Sugru moldable silicone
https://sugru.com/what-is-sugru
a challenge is how to test a custom height mount prior to road use
their website says it will hold 600 times it's weight or 4.4 lbs whistling not sure if that increases with more product. Some complaints on AMZ about the quantity in the packages being less than a grab and go ketchup pack shruggy beer
