Originally Posted by gregcharger72
ok that makes sense, thanks. I'm using QA1 stocker star double adj. I looked into santhuff shocks....wow are they expensive!
Does a mid 10 sec car really need a shock like santhuffs? what are other good shock choices?
Contact Ron Galbreath at Afterworks , he sells Vikings or possible he can re valve your current shocks .
Yes , top shelf parts are expensive . No way around it . I had santuffs front and rear , and just upgraded , was it expensive? Yes it was ….it really comes down to how serious you are , and what you are trying to do . Budget stuff can work , but it only gets you so far ,
....BAD A$$ STREET CAR.....
