Depends on what you want.. styling? function/purpose? comfort/handling????
The YearOne 17x9 have a perfect backspacing and will easily accommodate tires 275-40-17 front and rear... no fender problems at all.... but they are a rather small diameter... but good for upgraded appearance and functioning.
RylissPro runs 315-30-18... but with special offset/backspacing rims.. AND he has aftermarket non-stock front and rear suspensions... another ball game.
Your 71-B-body rims should easily swap with the E-body.
Short sidewall tires are stiffer; offer better transient handling response, but also welcome damaged rims when low tire PSI vs pot-holes eventually come into the mix.
Taller sidewalls offer softer rides, but with less handling transitions.
For my street/hwy driving, I run 15x8 minilites (Superlite brand, 4.3/8: backspace); BFG T/A 255-60-15 front. 275-60-15 rear... nice ride, good cruising tires. No problems with fender clearance.
For track events, I run 18x11 minilites (ET brand, 5.5" backspace), Yokohama AO52 200TW 295-30-18, F/R... lips flushed as needed (done many years ago).
