One of the pitfalls in these kits is not enough support for heavy wet loads. So, I extended the support for the hoist bracket that attaches to the crossmembers.
I also had to fab up some sort of hinge brackets.I used the stock bed mounting plate and the hinge bolts thru the bumper hole on the frame.
