Like Greg mentioned….. data recording can definitely make you adjust your shift light. It’s pretty interesting how much “time” can go by from: see shift light, arm moves shifter, trans makes mechanical shift
My tach reads a little higher than my EFI does, it works out great, I pull the lever when I see 7000 and the actual shift takes place at 7000 +/- 50RPM or so.
