when one is using a deep [in this case, a three inch deeper aluminum] transmission pan, how far should the filter be from the bottom of the pan ?
i have fabricated several extensions, including o-ring groves for sealing to the valve body, so if i don't have the necessary/correct thickness of an extension to use, another one will be easy enough to whip up.
a big TIA to all that are way smarter than me on this subject ! bow
beer
