Originally Posted by challenger1320
I have a 557 B1 motor and a 588 B1 motor they are completely identical except for the displacement. The 588 is quicker (et) but the 557 is faster (mph) in the same car. The 557 has a center counter weight crank the 588 does not. You do the math.
Challenger, what trans, gears and ratio do tou run? Weight?
