I just lined up a straight edge on his pic from center of crank bolt to center of cam bolt and both dots are off. Looks like you have the crank spun too far past TDC. Back it up and both will most likely line up. Cam turns at half speed, that is still a tooth off.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
