If it is an original creative work it can be copyright protected.
If it is an original unique phrase that is used used in commerce, it can be trademark protected. You can't just trademark a name or a phrase to prevent somebody else from using it or for frivolous purposes. It needs to be used in some legitimate form of commerce. Also it cannot be something that is deemed to be generic.
I am not an expert on this, but I have looked into it, consulted with an attorney, and I do hold a registered trademark. TM
Edit: also a trademark trademark has geographical limitations. Say for example you you register a trademark but you only use it in your home state. People in other States could then use it . But if you use use it nationwide, then you are protected nationwide.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
