I think it's cuz water in the air/fuel mixture reduces detonation (aka water injection); if the water % in the air is higher, you should run more timing to help offset the reduction in O2.
Is that right, Al?
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
