Originally Posted by moparjo68
Ok. I have found out what each code means on the tag except for one item: 459AE which is on line 3 from the top. Anyone know?
PLUG YOUR VIN IN HERE: https://fcacommunity.force.com/RAM/s/equipment-listing IT WILL TELL YOU EVERYTHING YOUR TRUCK LEFT THE ASSEMBLY LINE down to the battery etc.,
Here's an example of a 1999 Dodge RAM 1500 info from a VIN I found online used truck sale:
