https://www.enginelabs.com/news/what-i-learned-today-with-jeff-smith-reverse-rod-bolt-stretch-tech/
This article says you can look up the ARP part number for a rod bolt, get the length, and measure it on an already assembled engine to determine if it has the proper stretch/torque.
I have not found the lengths to be sufficiently consistent. Even on one set of rods they vary enuff that I have reset the length gauge from one bolt to the next.
What have you found for length consistency?
[img]http://i.imgur.com/boeexFms.jpg[/img]
31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
