The part I am having trouble with is why the battery which should be at ~ 12.4- 12.6 won't keep the car running, but will start it powering both the starter and ignition, during which time the static V will drop to 11 or so volts due to the amps drawn by the starter.
I am not disagreeing or wanting to start an peeing contest but rather understand how low alternator output at idle makes the motor die but start right back up with less available V and I from the battery than was available when it died
If their are other large draws on the system BOOM BOOM STEREO, 50+ Amp fans and A/C Then it might make a bit more sense. Way back when, one would toggle switch the field connection off at the drag strip to take the drag off the motor
thanks for trying to make a hard headed pollock understand the above
