I'd think you have enough to overwhelm a typical 8" mopar converter. Sounds like you have a 9.5"? ...put that in!!! There's gotta be some low hanging fruit for loosing weight in that car? Sounds like you have a nice engine, I'd put some time into loosing weight before I stepped-up the engine anymore. If noting else, you brakes will thank you.
Biggest weight loss would be swapping out the cage to a CM one, it's not even a CDS one, it was made out of 1 3/4" steam pipe front to back. The tech guy was amazed how thick it was, even on the outside of the bends
![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
I'd guess swapping it would save 150 to 175 lbs but the cost
![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
. I also got it re-certed last time out and tech'd so we got another 3 years on every thing.I have a big 'chute as well but the car stops well just on the brakes only used it about twice just to see if it works.
