What is actually accomplished by pulling the springs and blocking it?
This effectively cancels the cushioning function of the accumulator...makes a firmer 1-2 upshift but risks damaging the rear clutch.
How can it damage the rear clutch when it is already applied in all forward gears? The only thing happening on the 1/2 shift is the front band is applied unless you manually shifted from 1st to 2nd with an auto shift valve body or a rear band apply manual valve body. In which case then the rear band is releasing on the 1/2 shift. At no point is the rear clutch released and re applied, it is constantly applied 1/2/3.
What damages the rear clutch is shifting from reverse to drive without coming to a stop. Effectively using the rear clutch as a vehicle brake.
