Originally Posted by Transman
Originally Posted by 70gtx440dana
It is pretty easy to stick a flat screwdriver into the chrome knob and give it a slight pry to the side. The knob will pop off allowing you to remove it. Re-install using a vice and a socket to press it on. Done this many times with success.
Once the chrome knob is removed you are saying the lock assy. can then be removed from the glove box door?
Yes....just take out the two screws from rear of lock.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
