Originally Posted by moparx
not a fan of lokar "stuff" either.
it looks like the fittings need to be removed, then use a 90 degree 1/8npt male to 5/16 [maybe 1/4 ?] female tube fitting.
point it toward the front, then bend the output line to fit around the linkage in all positions it might encounter.
beer
Doesn't look like a 90 to tube will thread in without hitting the case frown
