Yeah on that pass it might have been making between 750 and 800 hp. The outside air was good. The air inside the engine was 98 kpa and 71 degrees. The scoop really cools the air down a ton. The air temp inside the intake is over 100 degrees on the starting line but is down to 70 degrees at the finish.
