The PCM/SBEC does not feed power to the ASD.
I guess you skipped over where I said
Wiring is not my forte, I hate it personally. rant
Anyone have any ideas of what I should be looking for?
The wiring schematic that I have shows the blue/white stripe wire coming from the PCM, just like the blue/yellow stripe wire also from the PCM.
The red power wire comes off the alternator/battery feed.
The green wire goes to the fuel pump.
I stated this already.
The blue/white wire and the blue/yellow wire are what actuates the solenoid.
One of them has to feed positive and the other is a ground.
Feel free to explain what I'm missing here...........
