With that much oil in every cylinder, where else can it be coming from? Oil dripping from the header collector flange, that is a LOT of oil. Can't be the valve guides. Unless there was some kind of gross assembly error, can't be the oil rings with an engine that only has 750 miles on it. The OP said he checked the PCV and it is functioning, so...... Without knowing what CR and cam the engine has, those compression numbers may not be out of line. Not everyone is running 13.5:1, LOL!
"We live in a time when intelligent people are being silenced so that stupid people won't be offended".
